Wastegate Hoses
86 TR
Work In Progress
Got a question. Just put a TE60 turbo on my car yesterday and was wondering can you lengthen the wastegate hoses or can you buy longer ones??
The hoses on my turbo especially the one on the front of the compressor housing is really stretched out to make it fit.:confused:
Thanks.
Yes, you can simply replace all of the hoses with the same size vacuum hose available at your local Autozone. Cut the hose to length so they fit the best way , but make sure to make note of how the hoses are routed to the grey Y and how they hook up to the wastegate solenoid if you are still running it.
In this case, hose length does not affect operation.
Patrick
