You need to call Precision Turbo and get the correct adaptor bracket and hardware.
# 219-996-7832 ask for either Pete or Jim. They should know what you're talking about.
Tell them you have a Garrett TO4S compressor cover equipped turbo, and you need the special billet aluminum wastegate adaptor bracket and the special hardware that goes with it. It is a special bracket, that to my knowledge, PTE is the only company in the world who makes it, that will properly bolt up the stock Buick style wastegate actuators when using the Garrett TO4S compressor cover. There might be other companies that make similar hardware, but I have yet to see it on a Garrett TO4S compressor cover. It has to do with the bolt patterns being different on all the compressor covers.
This bracket will only work with the compressor cover clocked in the stock orientation. Meaning, the compressor discharge points straight and level towards the front of the car. This bracket will not work very well on applications that have intercooler pipes that force the compressor cover to be clocked at a 45* angle. No workie too good. But works fine for a stock location IC or an IC pipe that has the 90* bend in it, it will work.
It's very important that you get the correct hardware for this bracket, as it uses a recessed screw that will be covered by the actuator. And it will only go on one way. Here is a picture that you can just see the top of this adaptor bracket bolted in the correct position on a PT6776S turbo. It's just to the left of the vacume barb.
The stock wastegate actuator bolts on top of this adaptor bracket. So, first you bolt this bracket to the turbo, using the regular bolt on top and the special recessed bolt on bottom, then bolt the actuator to this bracket.
It can be a real PITA, but it will work.
I don't recommend running the actuator with only one bolt holding on, as the actuator will flop around when it starts moving under WOT.
HTH
Patrick
