I have been chasing a mysterious knocking noise coming from my engine compartment. At first I thought it was the notorious crack in my exhaust header. But after inspection it wasn't. It would only happen when the car was under normal accelerating. I then thought it was a lifter. Not that. Well I found the problem. I have a ATR 3" downpipe. The wastegate puck was rattling! I turned my boost way down because my turbo is beginning to leak and the wastegate actuator was kinda loose. That's what was causing the puck to rattle.
Now..... I tightened up the actuator so the puck does rattle under normal acceleration. Not when I boost to about 10 PSI I hear the rattle even louder! Does this sound like the actuator is failing around 10PSI and causing the puck to bounce back and forth? Maybe the controller is loosing vacuum and releasing and activating in rapid succession?
I'm also getting a lot of oil coming out of the controller on the value cover. I believe that is the oil from the turbo leak.
Any suggestions? New Actuator? I know I need a new turbo.
Thanks!
Thanks!
