carryon525
- Feb 22, 2016
So I wanted to lower my boost to see if the knock issue had to do with "to much boost" and I took the rod loose and pulled it off the puck nipple and the rod immediately pulled itself far from the nipple. I had to pull extremely hard to get it back over the nipple and almost gave up trying. My question is does this mean someone was trying to turn the boost way high and would that affect the gate opening? I watched the video to learn how to properly "preload" and did it exactly how the guy explain AND I do have a Lorenz Boost controller now that I will use to adjust boost. Does it sound like I've done this correctly?
