wastegate?s and wheres kirbans?
87GNcospg
Send your Donations
is it necessary to run the Heavy duty actuator if i already have RJCs boost controller? i plan on running about 22psi at the track.
will the spring in a stock actuator and the RJC controller get me to 22psi or should i just get the HD actuator?
is kirbans performance still around? if not should i just order a TE style internal wastegate from precision? any one know who has the best prices as of right now?
TIA
john craig at limit can get you whatever you need as far as wasgate , but you should be able to get to almost 26 with RJC controller and a stock WG , 22 shouldnt be a problem
