Wastegate soleniod ????
Has power to the solenoid, can adjust boost manually by turning the rod, changed wastegate actuator and put a new original y on with new hoses. What else do I need to do?
I can turn the rod and force it to make more boost but want the ecm to control everything.
The adjustable wastegate actuator is adjustable so we can adjust the boost level.
Are you wanting to run the factory 12 psi boost and can't get there?
If you want to run higher boost than factory, that may require a different chip to have the ECM control the wastegate solenoid at the boost level you're after.
And yes, leave the "Y" hoses on the wastegate if you would like the ECM to control the boost.
