I pulled the elbow off and found no oil after a run into town. When I was removing it one of the bolts broke so I am soaking it and am going to ez out it. I will put it back together and try the hose trick. The turbo spins freely with very little side play. I looked in the "Y" fitting but didnt see the orifice I have read about. Not sure if I need one of those also. I plan on getting it back together tomorrow. The "donut" seal is not in the best of shape but I will just put it back in. If the hose trick gets my boost back then I will let you know. I will also try and switch the "Y" fitting around just incase it was put on worng from the engine rebuild. This is just very frustrating Let me know how much just in case. thanks T
