Hello, I currently have Hooker headers/crossovers/3in. THDP/ext. ATR wastegate. I normally run about 19lbs. on the street, and recently I found the paperwork for my wastegate, and tried adjusting it to see if I could quicken spool. It worked, but now my max PSI(@ WOT) is 13lbs. So I tried to adjust it back, but to no avail. I can adjust the thing all the way in or out, or anywhere inbewteen, and still 13lbs. I am thinking that the spring is weak? Anyways, I realize it is not a "reliable" part anyways, so I was considering getting a racegate. I need to know weither a racegate will bolt right up to my setup now(I can send pics if it will help you visualize). Or if I am going to have to have custom stuff welded to make it fit. Also, could someone explain how the different spring rates work(black spring = 9psi.)?
In need of help!
,Thanks -DC
P.S. I am reaching 12psi @ ~1/2 throttle(car is not fun to drive with this low boost).
In need of help!
,Thanks -DC
