Superskwrl
- Nov 27, 2001
I have been toying with the Idea of a small JY water/air ic. And it's just gonna be a small experiment on my car. I have not decided what JY cores to use, it's most likely a SVO or DSM core (svo looks easier to work with)
(Design 1) I have read several place that with a Water/Air the air goes across what is normally the outside of the intercooler and the water goes where the air normally is.
(Desgin 2) Yet i have seen several examples of what appears to be Air/Air ic's with boxes built around them that the water is in, which is what this post is about.
I have seen the vortech powercoolers and they are fairly small, even the mondo cooler is not that big and alledgedly supports 1400hp?
I would think the the overall flow would be higher using water through the core,(design 1) however is it possible for it to be free flowing, and the air charge not being cooled enough?
(Desgin 2)The other thought is if i used 2 JY cores (Dsm's are 4" thick SVO's 3" thick) sandwhiched togeth doubling the thickness i could make new end tanks with larger inlet/outlet's and a better tank design because imo (most if the stock ic's tank designs leave something to be desired) and the overall flow would be acceptable 900cfm?
Another question is, although i dont think it will have room using Design 1 making a reservoir with access on the ic itself to loading with ice and have another remote tank and small pump for more more+ice
Any thoughts are appreciated
