Waterpump bolts
I just bought some at my local hardware store in stainless. They Look nice.
You need:
3 ea. 5/16-18 x 4 1/2"
1 5/16-18 x 5"
I used flat washers and permatex 14a thread sealant. Torque to 22 ft lb.
You need:
1 5/16-18 x 5"
Thank you sir, you've been most kind doing all the leg work and passing along the info :)
I'm looking for the 4 long waterpump mounting bolts. Thanks
Tom
I actually took all the water pump bolts with me and did them all in stainless. Since I was doing timing Chain I did the front cover bolts in stainless also. All except the bottom 2 studs on the front cover and the top stud on the water pump. Couldn't find those.
for some reason that top stud thing on the waterpump is metric threads
