Rickerbucks
- Feb 18, 2003
Hey guys.
I sent my ECU and WB sensor to FAST and they sent it back saying that it was fine. They sent a data log that basically proved it was OK.
However, I have it installed and although the the computer "sees" the WB - there is a Lambda signal on the screen - it is not getting a reading from the sensor. it just stays stuck at 15.94. It does not move. Not at all.
I checked for exhaust leaks. There is no audible or visible evidance of a leak at the header or at the plugged air pump bung.
I checked that the harness was wired correctly and it does appear to be all wired correctly.
What else can I do to try and check things?
