N.W. Buick
- Aug 15, 2001
Looking for the 'entire' rpm range of this cam - 1500-5500? 2000-6000? Guys running it thoughts on Good Bottom End to Mid-range? Any problems going through state emissions testing?
Not planning to buzz the motor much over 5600 rpm - max 5800.
Currently being assembled engine combo: T/A - SI aluminum heads, 65MM Throttle Body, Front Mount I.C., Vigilante 3000 l/u converter, 6776 BB turbo, twin Quad-Air pumps in tank, injectors 55#'s for on the street - will 'detune' as needed 72#'s for the track may go 83#'s if needed.
