Well I just got this car together, it was a roller I purchased and an engine that I had already built.
Anyhow, I have a weird binding in the column and was wondering what I should look for first...
This is the problem,
Key turns and starts right up in park, no weird binding, and linkage adjustment is right on.
With key on, I can only shift into reverse and neutral is kinda forced; this is with the car running or not.
With key in accessory, shifts all the way through the pattern with no problems.
From underneath the car there is no binding at all.
The key will only turn over completely from park, not in neutral...
So?? Where should I start. Something is obviously binding in the column, but what??
From my understanding the neutral safety switch is just a switch and wont cause binding... Is there some rod in the column that I need to check?? TIA
