Ok I am getting ready for the drags and I installed a battery disconnect in the trunk, and when I first disengaged the battery disconnect, the car kept running due to how I had the alternator output wire connected. This is where I noticed the issue and it is: If the alternator is hooked up the system is at 14.8 volts and everything runs fine. If I disconnect the alternator so it is not charging (is at 12.8 volts) the car will not idle and hunts if you let the RPM's go below 2K. When I plug in the alternator back in, the volts go back up to 14.8 everything is fine again. This is very repeatable, has anyone ever noticed this? Thanks, James
