ski_dwn_it
- May 3, 2005
launch of 434 using Gen7. Running it through a Innovate WB, same setup as last year computer/ECM/Setup wise with the exception of two thing. Cam and injectors.
Upped the lift of the cam and went from 30lb injectors to 42lb injectors. Cam change was not that significant.
Drove the car around a little after the rebuild and it ran flawlessly, as did it the year before. Decided to up the injectors to 42lbers after seeing some higher duty cycles when spinning it near 7300rpm. Last year shifted at 6900rpm, and went best of 10.1@134.9mph.
After the install of the injectors can again cruised around fine, but when I would drop the hammer on the launch off an idle of about 2k, the car would bog/launch/bog/launch.... I would then let off and roll onto the throttle and the car would scream like a raped ape. Went nearly 30mph in the last half of the track. Went a best of 10.4@132 in worse weather than last year, when above ET was obtained.
This week I checked everything I could imagine. FIlter etc....all checked out.
Went out today to an 1/8 mile track and car instantly off the trailer started doing it again. Its like it knows when I drive 2hrs one way to start pissing me off! Tried about everything today. Added lots of AE, this aggavated the problem, the car then started to just cut out to the point of zero noise, like someone turned off the key. Would do it time and time again......
I loaded my old tune back in, left everything the same and car still acted the same. Didn't even go back out onto the track....just hit it on the pit road and it was obvious.....even in the GRASS it would cut out!
Came home and pissed off, I put the old 30# inj back in. Started the car and even hitting the throttle off idle sounded quick and crisp. Like last year. With the other injectors in it, it was laaaaaazzzzzyyyyy sounding even just punching it off idle. Pulled the car around in the driveway and hit the gas, the slicks instantly spun and the motor had zero hesitation.
Now with both inj there was time dialing in idle and part throttle, I was leaving the WOT to the track where its safer. LAst year when I got the system I was able to dial in the 30# injectors on the setup in within a few runs. This year NOTHING seems to be working.
WEird thing is the WB is saying that the motor is running lean like WAY lean when it acts up, yet NOTHING even leaving the constant at 30 in the system setting, with the 42 injectors did NOTHING to help it.
I was able to get 2 runs off all year clean with these injectors. Its like they are locking up or something. PLugs are white as a ghost also!
COuld these injectors be bad? Are there injectors that are not compatible with the DFI system? These are straight ford SVO 42# injectors. Just like the 30# injectors.
Any ideas?
Any ideas?
