weird problem
85 conversion
the 9's are in my reach!
i was running the crap out of my car one night when it started missing real bad. it was running real rich and ended up fouling all the plugs. i replaced the plugs and it runs much better BUT its still running rich and when you step on it and just before you get into boost is will mis a bit and then when it hits boost it runs great. normal driving it will miss every once and a wile and it does idle a bit rough but that prob because of how rich it is. when i say mis its not just one or two its kinda like soft touch rev limiter just not as bad just before i hit boost. I did check TPS and its working great with no dead spots and also disconnected cam sensor after start and car still ran. ANY IDEAS???
When you say the cam sensor broke, is it because the cam sensor failed or the mechanical part internally broke which RJC sells (cam sensor repair kit for $22)?
