weird rpm numbers
ledzeppac
when i am cruising around with the RPMs at 1800-2100 the GN will act a little weird. If i let off the gas the rpms on the scanmaster will sometimes go up to 3500 and eventually work there way back down. if i touch the gas a little bit while the rpms are working their way down from 3000+, they will go back to normal. this happens when the car is in drive, not overdrive. when i do let off the gas i can sometimes hear the the motor reving up for some reason but no where past 3000rpm.
I have the same problem. Any ideas?
achillies last stand..........
ummmm well that is one of my top three songs ever and probably musically the best Zeppelin song. And most likely the musically the best hard rock song BUT...
it doesn't anwser the question!
I think I'll play some Achilles right now:D
IT IS IN THE TOP 3right next to juniors eyes on never say die.you know that one?symtomoftheuniverse.its atight run between the two groups.
I assume Sabbath... Actually I don't. I have, actually my dad has the RECORD "Never Say Die" but the turntable needle needs replacing so I havn't listened to it. I'll download it tonight.
My 3 goes
Dazed and Confused *live
MOBY ****ING DICK again *live
Then Achilled Last Stand
