Well, my DD finally dropped the idler pulley yesterday @ nearly 168K.
So, today I go to fix it @ my friends place where I dropped it after work yesterday.
New part from NAPA is exact same diameter as original, Only cost me about $20, WooHoo!! But then the belt wouldn't go back on.
Needed 1/8" more slack all around the AC compressor. It makes contact with about half of that pulleys diameter. So I broke the tensioner trying to get it.
There went another $40! So, that musta been my problem, right? It was already broke, I just finished it off. NO!!!
New tensioner. Same problem. The same belt that I'd had on the car for the past 48K will no longer fit!!!! Mind you, I just had this belt off two weeks ago! It went on again just fine then!
Back to Auto Zone. Third visit to a parts store in three hours of cussing. The belt is the correct 83-1/2" belt. He brings out a fresh one, it's about 1/16" shorter than mine strectched out between my arms. That won't work, mine won't work. So I buy an 84" belt. $30 more or something. Goes on fine, has a minor but annoying rattle/slap sound when the engine kicks off of the starter, and when I underslip the clutch from a stop.
Seriously, What In The WORLD just happened here????????????????????????????????????
Is this just insane? Is there some way to adjust something to fix this issue? WEIRD!!!!
Nothing on this set-up adjust's but that tensioner!!! I've replaced everything but the AC pump now.
I'm stumped.
My friend said that I handled it alot better than he would've. Just kept goin to the store, n adjusting for the ridiculousness.
I'm stumped.
