I have owned my current Buick a total of 4 months. In that time, I have put maybe 80-90 soft street miles on it. About 55 of those miles were myself, my wife, our 7 year old daughter an our 18 month old son cruising to/from a local car show a few weeks back. Last Friday, I shut the car off at a local store. I return to the car 2 minutes later, start it up and there is a tapping sound (which sounds like it's coming from under the passenger valve cover) and the car feels like it's running on 3-4 cylinders. I'm less than a mile from my house, so I limped it home. Pissed off, I just park it in the garage and go about my weekend.
I have had to add coolant to the car twice since owning it and I did not know where it was going. No smoke from the exhaust and no visual leaks or puddles. Well, it appears the car is low on coolant again. I also popped off the driver's side valve cover breather and there looked to be a lot of moisture in there...with a swipe of the finger, it was kind of a greasy clear/white texture.
I assume my next step should be to drain the oil and look for coolant in the oil? Any ideas of what I may be looking at here? Head gasket? The tapping under the valve cover scares me too. I've had broken rocker shafts on other cars in the past and that is what it sounds/looks like, but the coolant loss really concerns me and has been happening since day 1 of this car being shipped from Maryland.
Time line:
Mid July - Car arrives on a truck at my home.
A few days later (after getting Texas plates and putting a total of about 1 mile on the car) the car won't start. Dead Alternator...replace alternator.
Next day the cam sensor starts acting up...Locate stock sensor, replace the next week.
A few days later...dead battery...replace under warranty.
After finally getting the car in "running shape", I drive it a total of 10 miles. Engine temp is getting near 200°. Check coolant...quite low. Top off coolant.
Put another 50-60 miles on it without issue. The above problem happens. Check coolant...low again!
I now realize the coolant loss problem had to be existing when the car was sold to me and I suspsect the cam sensor issue was also pre-existing. Not really what I expected after paying $16k + shipping for a car off this board.
Sorry for such a long post, I was venting a bit there towards the end.
Any ideas, suggestion on the steps I should take from this point forward?
Time line:
