- May 25, 2001
I had a timing cover issue an have the front of the motor apart in the car. I pulled the plugs out and found this:
Plug on the right is from #1, plug on the left is from #2. All except #1 look like #2. The plug looks wet, the car has not been run for over a month so it's not fuel. I can see down the plug hole and the top of the piston looks clean. This car had no water in the oil and no bubbling like it had a blown HG.
Anything else that can cause this?
