Turbo6Smackdown
- Dec 31, 2005
Why don't your sensor last in high octane?
SignUp Now!It's always best to have some kind of display, otherwise you're stuck with having a laptop sitting in the car all the time. That's why the powerlogger and scanmaster 2.2 are such a great combo.
I'm assuming that the scanmaster is turned into a wideband A/F ratio monitor by the powerloggger? So thennnnn who's watchin the KR screen then?? That's the most important screen to watch isn't it??
You should have a way to display. On my only run this year, I was seeing no knock, but my wideband read 12.6, way too lean. If I had stayed in it, something would have melted. I traced it back to my 2nd fuel pump not kicking on, as I adjusted the hobbs switch with a very crude boost source. I had the GEN 2 set to add 40% extra fuel at high rpms hoping to be super rich, so 1 340 pump supplied almost enough for the 1/8 mile.
If your car was lean, wouldn't it start to knock? And couldn't you have seen a lean condition with the standard O2 sensor?
So a scanmaster, with kr and wb 02's is ok? Just tryin to figure this out, so I can make one order, and not have to order more crap down the line.
And what's recording my run. The post above said the powerlogger. If that's true. then where in the plogger am I looking for the results after the run ?
Turbo6Smackdown;2298622 Your powerlogger records it? So you look into the powerlogger after your run for the logs?[/QUOTE said:Exactly.
I know the difference between narrow and wide but, would that matter if your run's lean condition still woulda showed on the narrowband? With maybe a 500 or something reading?
And the powerlogger has a readout screen? I didn't know that. And how long of a run can be stored on the laptop? Are those files big?
I see. I say this because as I read more, I keep hearing how stupid widebands are, and how people have been tuning just fine without them. I tend to think that's wrong but,,, the proof is there. People have indeed been tuning without them for years. Whaddy think?
