Through the mufflers still. I have a THDP for it with an electric cutout on it, but I haven't had time to put it on yet.Are you running it through the mufflers or open dump?
No, the timing chain has been replaced.Original timing chain?
Yes. Sigh...it's slipping a lot. According to the log, the rpm drops from 5,553 to 5,066 on the 1-2 shift. On the 2-3 shift, the rpm goes from 5,391 to 4,818 RPM.What others have said.......
Also, this is another indicator of a converter issue. "PTC 2,800-3,000 stall converter (stalls closer to 4,000 at the track on a set of slicks)". Jerr's slip calcs are "scary"!
A look at the rpm scan shows low rpm drop on the shifts. Can you post what they are?
Thanks for the write up Julio. I'll work on your suggestions. It sounds like there still may be some left in it.I was going to say that. Hope its been changed.
Power comes from moving air and fuel. Just because you run a lot of boost doesn't mean anything. You need to work on maximizing the car on a lower boost level and try and figure out what it likes and doesn't. Arbitrarily throwing a bunch of boost doesn't solve anything but get head gaskets popped out. It has to do with back pressure. Think of blowing air through a coffee straw.
Only increase boost as the car responds to it. If not.. you'll end up with 35 psi at 12.0 time slip.
Your 60 foot needs work. Exhaust needs work. Keeping engine RPM's under 5k with a stock cam=locking converter. getting slip down(locking converter)..
Me.. install timing chain if that hasnt been done.. then down pipe, open cutout, bring boost down to 23 psi.. and play with timing and air fuel at that lower boost level. Figure out what gives the most MPH at that lower boost. This will tell you what the motor likes. Apply that knowledge to 24, 25, 26, etc PSI.. and every psi the MPH should pickup if the motor responds properly. I use the pickup speed in MPH from 1/8-1/4. If your 1/8 MPH goes up and the 1/4 doesn't respond the same.. back it down and look. At your performance level i'd say 22-23 mph pickup. So 90 in the 1/8 should be 112-113 in the 1/4
Understand leakdown and condition of motor plays a role in this. If its tired.. its tired.
The fastest stock turbo, stock long block car ran 11.37 at 116.50. 1.50 60 foot, 28x9 slicks, 28 psi 1st gear and 23-24 through the traps. 45-50 degree weather 92 octane fuel, and meth injection.
Getting that 60 down 2 tenths.. and managing rpms.. gets you there
Hope this helps.
The methanol setup is rock solid. Niece piece. Thanks.
