What are thoughts on SouthSide Lift Bars (Now made by Lakewood)
The Milan night was last Tuesday. I haven't had the South sides on for about 10 years. My current set-up is stock control arms w/urethane bushings in the lowers only, 10 lbs of air in the right airbag, and a homemade pinion snubber. 20 lbs of air in the tires, leaving a "0" boost. best 60' was 1.72. When I tried to leave with any boost at all my 60' was slower.
Larry
Ya I missed that one because it was not the one I was enviteted to :(
Anyway I am going this way I think I want to be able to lift the front wheels at some point in the futur so I am most definnetly lookin to hook hard with boost at the start line :D
Larry you goin to the GM Event this weekend?? If so let me know so we can meet up how much you want for the SSM bars and also are the solid bushings still good??
Derek
Derek,
Unfortunately, I'll miss the GM event. (wedding anniversary this weekend) I'll have to check the bars. I think everything is good, but i"ll have to confirm. I'll take $75 bucks for them. If you want to come over and see them let me know. How do you like the ALKY kit? It's in my plan for this winter.
Regards,
Larry Smith said:
Derek,
Regards,
ALKY RULES!!!!!!!!!!!!!!!!!!!
Larry I can not tell you how much I like it just can not put the added Boost into words!! 24-25psi and I know this car will be in the solid 11 sec rang once she hooks up!! I am looking at also adding 2 new air bags (Found out the one in the pass side now has a slow leak) the SSM bars some welding on the Mounts and also some adjustable upper control arms :D
The I am thinking some 3" welds for the front and 8" with the ne M/T Drag Radials for the rear :) If she dosnt stand up and scoot then I will be at a loss for words lol.
The once she hooks good we will due the trans and converter :)
We may just make it to the 10's with a te44 and everyone says they wont due that lol.
Anyway I am very interested in your SSM Bars Shoot me a time when I can stop by or meet up and Ill be there.
Happy Anniversary also :D
