What B&M shifter works with the stock center console?
ttypewhite
I saw a few guys in BG with Turbo 400's in them, running a B&M shifter that uses the stock center console with the stock console for the shifter to come through with the 200R4. Whats the name or part # of that shifter. I like the stock appearance inside the car. I just got a T400 w/ transbrake and would like to order one ASAP. If anyone has one that they want to sell me, give me a PM with a price and I will get right back to ya, or tell me who has the best price on them.
There are several. Most require extensive cutting and a custom top plate.
I am using a Pro Ratchet. Supposed to be the best of the ratchet type, which some say are dangerous to use. I only had to make some minor cutting on the middle layer of the console and it will still allow me to reinstall the stock shifter.
I also had to remove the mount that is welded to the tunnel, but that can be re-welded again.
Also removed the gear indicator lens from the top plate, but that can be glued back on.
I won't have any gear indicator. The shift lever comes up thru the stock location and the reverse lockout thru the old gear indicator.
Still a work in progress, but I have mocked it all up except the actually mount to the tunnel (flat shifter to round tunnel) which is just a matter of getting it mounted solidly (plenty of clearance).
Tom
Thank you for the response. But what I am looking for looks like this.
I took a pic of this one in BG but the guy who owned the car was not there so I couldn't ask him what it was. But I saw other cars like that as well, but with the B&M ball for the shifter. Not the stock one. Does anyone know the name of this shifter. I do not want to cut my faceplate or have to put a sheetmetal cutout in its place.http://www.imagestation.com/picture/sraid119/p5caa26f3a919dfb2d7f05bede5661f6e/f86ef853.jpg
Just finished an install on one, I will get you the part number off the box when i get home.
Looks MINT!!!!!!
I had to cut nothing.
There ya go. Thank you RICHIE HIGH PSI. That would be greatly appreciated.:)
Quicksilver
That's just the generic fit model, if that fits shouldn't the others fit as well, such as the Megashifter? I just dislike the quicksilver myself.
I'd really love to see pics of how that install looks..
Thanks again RICHIE HIGH PSI. Who gives the best price on these shifters?
i just installed the b&m mega shifter worked out perfect send me your email and i will send you a pic
