I had gotten on my 87 GN and after a small pop I noticed a knock in the engine. With marriage, kids, and career the car sat for a few years. I recently popped off the valve covers and discovered a cracked rocker arm shaft. The plastic retainer that attaches the rocker arm to the shaft was off on the front left and the shaft was cracked about 1 1/2 inches from the end. First of all, what's with the plastic parts? I was shocked when the first thing I found was the broken retainer top. The rocker arm was still sitting on the pushrod which wasn't damaged. I was going to replace the shaft, rocker arms, and pushrods, and oil pump(in case it was an issue) but was concerned if I should worry about any other damage. The car starts at the touch of a key the couple times I had to moved it but I'm skeptical that the fix will not be this simple. It's an inexpensive fix but don't want to throw money away if it's more.
Also, I've heard it's not good for the turbos sit...anyone have any suggestions to make the most out of this possible rebirth. Car is mostly stock with 64,000 miles, original chip, 40lb. injectors, Flowmaster exhaust, Lunati cam.
