- May 28, 2001
I would think that..
"How does one dispute such a claim. Detonation is a gray area, it lies in between a good tune and a bad one, or between a good engine and a spun bearing, or between a busted engine being the customers fault vs the ability and knowhow of the engine builder. I am not a tunning master, but I can read a scanmaster and an EGT probe. I chase fuel with boost, not the other way around."
A. Disputing such a claim starts with some diagnosis as to what the problem REALLY is/are, and what the possible causes are. [Be there when the builder does his inspection.]
B. Detonation is not, IMO, a gray area. There are many indicators, from plug readings, brg condition, piston condition, etc. Again, refer to "part A".
C. Relying on a "Scanbastard", and an EGT meter, is too little, too late, when attempting to prevent a failure. Both these devices are waay behind the time curve when reporting a possible problem.....
Maybe a WB with some recording channels?? Like you suggested, sneak up on the max power. I'd suggest doing it with a more reliable data stream.
Just my $.02.
Back under my rock....
Just my $.02.
