OneLethal87GN
R.I.P. Lethal GN
- May 26, 2001
After a fresh rebuild the tranny shifts normal under light throttle and will shift firm enough to chirp the tires at moderate throttle, if done back to back to get pressures up. If you give it 1/3 throttle, or enough to build 3-5 psi, the shifts are barely felt and it seems to not want to hold the gear like it should. This is mainly on the 1-2 shift because I really haven't tested it much on the 2-3 or 3-4 shifts. The band is an alto red eagle racing wide band. The tranny has one of Bruce's shift kits and a 200 servo has been installed. The tranny was rebuilt using stock parts. The valve body was replaced with a non-performance one but the tranny did the same thing when the BQ body was in there. I haven't tried a WOT test on it since the newest rebuild since only low boost would seem to overpower the tranny. I asked for a pressure test to be done but they didn't want to do it. Most of you already know that Aamco did the rebuild and I know that was my biggest mistake. I watched the guy rebuild the tranny this time and he kind of just threw it together. I didn't see him check for clearances at any point during the build. His method of checking band clearance was simply to see if the tranny would rotate by hand. After playing with the servo and getting it to the point where the tranny would rotate he moved on to the next part of the build. Could the problem be too loose band clearance or a pressure problem? I know it is best to get it checked by another builder but most seem to have the same idea of how to build a 200-4r. I really don't have the time or money to have it pulled and sent off to get checked, even though that is the best idea. Maybe one day a board member tranny builder will move to eastern N.C.
