Originally posted by TurboDave
Easy, in 86/87, gasoline quality was MUCH higher than it is today. It's a forgone conclusion that 22-23 degrees of timing is usually refered to as a 100 octane area, maybe 98 ;-)
But with todays gasoline mixtures/blends, somewhere around 19-20 degrees of timing is more than enough.
And one more reason. Back then 22º of timing was just fine for the factory designed boost level of 12#. Since most guys want to run at least 15+, that's just too much timing.
