What Chip?????
teddie87gn
i need a good chip the one i have know does not work well my set up is listed below. i have heard about the max effort chip is it worth the money and will it work with what i have
If you have the $$$ maxeffort, if not mt JC chip works good with these injectors
My understanding is that Steve Y (Maxeffort) makes the best chip on the market for the 40# Redstripes. I have never heard anyone complain about a Maxeffor tchip so if you can afford it, it will probably be the last chip you ever buy. Steve can easily upgrade your chip later on if you go to bigger injectors.
7th and 8th inj mounted in up pipe
That sounds like a calibration challenge, 2 additional injectors in the up pipe.
You may find that 6 big injectors versus 8 small ones would be an easier combination for the chip guys to calibrate.
