Dec 9, 2011 #1 1 1fast6 Active Member Joined Aug 2, 2010 Messages 1,521 Pulled my 2004R the other day and the converter that was in there has what appears to be "Z" stamped all the way around it. Are there any other markings to ID this converter? the replacement next to it:biggrin:
Dec 9, 2011 #2 1 1fast6 Active Member Joined Aug 2, 2010 Messages 1,521 I don't think it's a D5. Probably explains why it wouldn't spin the tires in the rain with a TE44.... Can someone decipher code; HDCB? I found this website but my converter code is not on it... http://www.gmtuners.com/gmtransinfo.htm there are some other stampings; 10 05 4677 L K1 2K 035
Dec 10, 2011 #3 1 1fast6 Active Member Joined Aug 2, 2010 Messages 1,521 well i've pretty much worn out google searching for info on this converter. was really just curious about what it came out of and the specified stall speed.
Dec 10, 2011 #4 B buickruss Active Member Joined May 25, 2001 Messages 877 What was your stall at 0 psi? I had a stock rebuild done on my trans years ago and it came back with a converter stalling about 1200 rpm
Dec 10, 2011 #5 G Grumpy Thread killer Joined May 24, 2001 Messages 13,822 Looks like a cheapo DACCO rebuilt one to me. They were the only "gray" converter I ran across in all the years playing with the trannys.
Dec 10, 2011 #6 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 If the tranny was painted grey as well it may have come from jasper. They seem to like grey for some reason, even on their converters.
Dec 10, 2011 #7 S SSedan64 JoaTMoN Joined Dec 8, 2007 Messages 1,590 1fast6 said: Can someone decipher code; HDCB? there are some other stampings; 10 05 4677 L K1 2K 035 Click to expand... ---K-factor----- (stall) Z = 203------- 2375rpm Z = Heavy Duty Spring Damper, Woven Carbon Material. Are you sure about the HDCB code? H = Rear Wheel Drive 200C, 2004R, 700R4 etc.., 1.750” Hub Diameter, B-24 Family. ------K-factor----- (stall) D = -- 180------- 2095rpm --------Damper style C = --Light Duty Spring Damper, Paper Friction Material. ----Bolt circle B = 237 MM.
