What do you think about these Mods?
newmoon
I am thinking about buying a 87 GN with these mods, I am wondering if it is setup correctly?
Brand new aluminum radiator, te-60 turbo w/ adj. wastegate actuator, adj. fuel press regulator, green stripe injectors, reds xp fuel pump with hotwire kit, g- bodys down pipe and 3" exhaust all the way back, gn1 perfromance air intake, Taylor racing wires, accell ign. coil, ac plugs,powermaster has been replaced with brand new vaccum brake setup, trans shift kit with stall converter, boost gauge, knock gauge,oil pressure gauge
Seems well outfitted. I didn't see mention of what the torque converter stall is. If you end up buying it, the first thing you should do is get a scanmaster or similar so you know what is going on. Just because it has the parts doesn't mean it is living up to its potential. :)
Sounds like a nice car..if u buy it u should at an alkycontrol kit from Julio runs about $590 but is worth every penny. Will allow u to run an additional 6-7psi over just 93 octane. The most I would go on 93 with that turbo is 18-19 Do u no what chip is in the car?
FYI.. With the right tune that extra 6psi could mean 70+whp. U havnt even come close to the sweet spot on that turbo at 18psi
