Well as most of you know i have been collecting S2 parts over the last year or so. I am just about set to go to assembly
The last piece i need is a good roller cam set-up, some machine shops are telling me that i should have the machine shop doing the work custom grind one. I am still undecided on that. With the pieces i have listed below, I am just trying to get some feedback as to HP level I should expect.
S2 Off-Center Block
GN1R Full race port heads
GN1 Roller Rocker Shafts
83LBS Injectors
3.580 Billet Crank
6.5 Rods
T76 Turbo 4 bolt housing
BG Off-Center Intake
70MM TBI
CAS V1 Front Mount.
ATR 4 bolt headers
Fast bank to bank
Weldon 2015 Fuel Pump
224/224 Roller Hydraulic Cam is what i would to run.
Thanks for any feedback. I am thinking 650-700hp.
S2 Off-Center Block
83LBS Injectors
3.580 Billet Crank
6.5 Rods
70MM TBI
CAS V1 Front Mount.
ATR 4 bolt headers
Fast bank to bank
