11s to 10s
we would reccomend the following upgrades to your car, sure some may have other opinions, but this package we believe will offer the most versatility, etc
T66, TE45a turbo.....sure you could get away with te44, pt51/54, etc.....but we believe the 66 or 45a will offer you the most capability to upgrade, another plus is their efficiency.
Street car? alchohol injection.....dual nozzle will offer you the most versatility with "mixed" fuels (pump gas/av fuel/110/114/116/120 octane) and allow you optimum tuneability RIGHT off the street.
intercooler, yes it can be done on a TTA with a big-neck, but we would reccomend either our 13 or 15-row units....we also offer a 17 row TTA specific intercooler that raises the core/offering much needed ground clearance 3 FULL INCHES above that of the 15-row unit.....you are going to need intercooler efficiency trying 10s with unported heads
205/210 cam/not absolutely necessary, but again....allows you to meet your goals with LESS boost, keeping the reliability factor in the picture. Head work will offer noticeable power gains with this cam/proven... Also, full race ported heads are not absolutely necessary on a high 10 second 3.8turbo.....simply gasket matching, valve job/matching bowl work you will get the most gains from......I would say 80% of flow/velocity gains in tta &8445 heads are found in bowl work.
Siemens 55lb/hr injectors, these babies will be effective into the mid-low 10s on the Fbody.
modified stock ECM, required with these injectors
3.5 MAF with 4" ends, again not absolutely necessary.....just helps get to your goal more effectively
Translator Plus (needed for use with the LT-1/LS1 sensor, also allows you to tune timing and fuel curves to optimize performance/anti detonation/alky tuning etc........almost eliminates the need to burn 5-10 chips to get it right.
stock plenum with PP, or MPE sheetmetal plenum
http://measeperformance.com/gn_plenum_tb.html
Good luck with your ventures, and remember.....tuning is the SINGLE most important aspect of going fast with the LC2 motor.....we see many customers (now) come to us with GN1s, JE's , girdle, capped motors with T66, T70 turbos...........and
their cars will not leave the 12s
Regards, <KM>@MPE
