a little gasoline chemestry for those that might not be in the know, as far as performance goes, you always use the lowest octane rating needed to control detonation, the higher the octane rating, the less susceptable the gas is to uncontrolled explosive combustion, gas in a IC engine is supposed to burn, not explode, octane is used to control the burn, but in doing so its rate of burn is slowed, so if you run a higher than needed octane rating than all you get is a theoretically speaking slower car, becasue the flame is burning slower than optimal, if 97 octane burned faster than 87, than you would notice the performance advantage when you switch any car to the higher octane rating, but you don't, all you get is the higher resistance to detonation, and if detionation wasn't a problem before, than you won't notice a thing,. but our cars being turbocharged the the control of turbo boost and other varibles being less than perfect ( old wategates, injectors, ........) its best to run the highest octane you can afford within reason, if your car is stock or slightly modded, the 98 octane stuff will work, but if your car seems track time then most will advise bumping up to the race gas, but the lead will eventully hurt o2 sensors and converters, but will save a headgasket, all of this is of course is ignoring those with water/alcohol injection, which f course is used to deter detionation, again by controlling the rate of burn and keeping it from exploding, proof again that octane doesn't cause gas to burn faster, cause last time i checked water doesn't burn too well,
Grant
Grant
