What gauge should I get?
BuickMike
Money pit
I have a new dual guage piller pod. The boost guage is going in one hole, so what are your opinions about what should go in the other spot? Keep in mind that I'm on a tight budget being a new Dad, so nothing crazy.
I've made the same decision recently....I decided to go with the knock guage from Poston. I've got the Scanmaster, but something that lights up and warns you that you can't miss and even tells you severity in color.....you can't go wrong. $79 unless you want the white face, which I believe is 10 bucks more.
boost and a tach. make sure its a 2 5/8th otherwise its to small to see as your doing a 115mph!
Thanks for the input so far. I'm not too big on the tach since I just leave it in drive and do not go fast enough in the 1/4 to worry yet. besides, I'll probably be going to a GNX style dash in the future.
The knock guage sounds like a wise investment.
Fuel Pressure. I've Got Fuel Pressure / Boost on the A-Pillar and Oil Pressure / Water Temp under the radio.
