What happened to my tranny
  • Thread starter Thread starter garrett
  • Start date Start date
G
garrett
Guest
I deicided to install a shift kit on my Ttype (86) to improve my subtle shifting.
I opted for an Art Carr due to the ease of install ( yeah right).
Everything went together as the instruction prescribed.
The car shifts fine from little to 3/4 throttle. But if I nail it it over revs the shift ( flare is th eproper term?) on 1-2 ans 2-3....
WTF is the matter????
The tech guy said I need a new servo...
The thing shifted fine before..chirp 'em and evrything.
Can anyone give me some ideas here?
thank You
Double check your fluid level first. If it's fine, get a pressure gauge put on the transmission. See if your line pressure is faltering over 3/4 throttle.
If it is screwy, there could be an issue with any of the following: TV valve train, VB gaskets, pressure regulator valve train, TV boost valve among other things.
Also, did you remove all of the old filter o-rings/seals from the pump bore when replacing the filter?
I added another quart of fluid, and made the TV cable as taught as possible and things are better but not as good as I desire them to be..
It shifts firmly, but not enough to chirp the tires ( my stock gn lights them up at 1-2 shift with no tranny mods).
I only removed one O ring from that port...are there more?
thanks
I'd say a pressure test is certainly in order. And, yes, there should have been just one O-ring in the filter bore.
