What Injecters do I have?
Sleeper-6
What Injectors do I have?
OK, I took a walk out in the rain today after work to check out the injecters on my car. I checked out the guide on gnttype but they're not there. They have a black body with a red plastic top. the numbers look like this if viewed from the side. On the projection where the plug attaches, it has the numbers "927". on the squared off section just above the barrel they have ther numbers "262" on top and "0280150756" below. Someone please let me know what these things are. Thanks again.
Look on the other side of the same injector if it has a small ford logo they might be early 30 pound supercharged thunder bird injectors (red tops).
Thank You. That they are. I should have known. That shop that did the engine work is known for doing a lot of Sy/Ty stuff. It all makes sense now. Thanks again.
