what injectors should I have?
sweetgn
I currently have a 210/205 cam, ported stock heads, bigger than stock valves, TE-61, 24 lbs. of boost with alky, rjc plate, ported intake, bigger throttle body(stock ported and new blade not sure how big), 3.42 gears, and a front mount intercooler. I currently run blue tops with the adjustable fuel pressure turned up pretty high (not really sure). Just put the TE-61 on this summer with no problems. Yesterday it was running fine/sputtering a little at 24 lbs. since it was getting down to 55 degrees yesterday. Last night I was driving in about 45 degree weather and when I tried to go up to 24 lbs. of boost it fell on its face. It did not do this in 70 degree weather and had no knock. I think the fuel injectors can't keep up. Anyone's thoughts? I haven't had it to the track since the turbo was put on, but with a TE-60 the best it had run was 12.95 at 16 lbs. of boost.
if you have a modded computer I got some simens 72 lbs for sale 200.00 shipped !, local not international LOL !
