What is needed
Donsturbo6
I want to change over to a TA33 turbo, and run E85 fuel. What other things need to be changed for this set-up to work. Also I want to change the torque converter. How much stall can I use without having a mushy gas pedel? I want it to remain streetable, and still want it to have the lock-up feature for the highway.
You will need an E85 chip from TT along with larger injectors. I use a 2800 stall converter with no problems. Some will say that a larger stall is better. Brad
Will need a higher volume fuel pump than the norm as well for higher boost
