What is the angle of the slash cut on a stock exhaust pipe?
TDmkr496
Getting ready to make a 3" exhaust for my 87 T. Can someone tell me what the angle is of the "slash cut" is on a stock tail pipe?
Take a measuring device and messure it. I think something as simple as a framing square can give you that angle.
I suspect he doesn't have a stock tailpipe to measure and was using the photo of the highway stars stock exhaust for reference.
I am intrigued what you will use for mufflers.
My exhaust is an old Conelys Performance Plus Mag Tune system I purchased in '91. I like to go 1/3rd down from the top and cut it at approx. 45•.
Not stock, just giving you some ideas.
^^ You are correct, I do not have a stock tail pipe to measure. I'm making a 3" system and so I was trying to try and keep a stock look kinda haha...
I had to bring this back from the dead because when I was helping my mom clean out some old buildings on the farm that are coming down soon I found the stock muffler from my car that I removed the summer of '87.
It measures right at 32 deg. starting 5/8" down from the top.
The end is flat at the top, then angles from there.
Measure down 5/8", then start your 32 deg. angle cut.
This info is more than likely too late for the OP, but hopefully it will help someone down the line.
