Choosing the correct back spacing depends on how wide is the wheel...I have some 15"x8"s with a rear spacing of 3.5 and they fit ok. I also have some 15"x10"s with a rear spacing of 4.5" which also fit ok...Both these wheels have the same P275-60-15 tires on them.
What happens is that when you go to a wider wheel (like going from 8" wide to 10" wide), assuming you're using the same tire size, the sidewall of the tire gets a little more "stretched" to seat on the wider rim, reducing the sidewall bulge, and therefore increasing the clearance between the tire and the car's frame. So you can select a wide wheel with more rear spacing than you would on a narrower wheel...
I dunno if I explained correctly though...:redface:
Claude.
P.S: as for why some manufacturers don't offer wheels with a rear spacing of 4"...I dunno for sure, but it's likely to be a question of demand...
