Oct 4, 2002 #1 6 6pack T-Time Joined May 27, 2001 Messages 740 With the wastegate loose, not attached to the puck arm. Actually I need to know what is the length on the half from the adjusting nut to the puck arm is.
Oct 4, 2002 #2 U UNGN Can't Re- Member Joined May 24, 2001 Messages 14,029 From the face of the actuator to the center of the hole, 5" will get you close to stock. My '86 GN was 4.9", my '86 T was a little more than 5". Every .050" shorter than this is a 1 psi increase in boost.
Oct 4, 2002 #3 6 6pack T-Time Joined May 27, 2001 Messages 740 So at 5 iches I will be at stock boost levels? Thanks UNGN!!!
