The factory heater tube fitting has a restrictor INSIDE the tube. Look at the small hole inside. It is not the standard ID of the fitting. I just run a 1/4NPT tap in there and screw in a brass pipe plug, then drill to size. (sorry, but I don't recall the actual size, but I think it's 3/16", but measure the factory one to be sure......use a drill bit to measure.) If you just screw in a new pipe fitting (using thread sealer
) the volume of water that goes through it will pop the heater core. Ask ME how I know that.:redface:
The amount of torque required to break the casting is pretty heavy. If you use a std 1/2 ratchet to tighten it, you probably can't break the manifold.
