What is this noise from the transmission
jimski
In over my head
Is this the converter ? It is shifting and driving. Please Help identify this noise.
I would check the bolts that attach the converter to the flywheel to see if they are loose.
I don't hear anything out of the ordinary.......is it a specific noise you speak of? At idle, or when your revving it?
I do hear a slight ticking if that's what you mean, but it almost sounds like injectors
difficult to say from the video, something is not right though,i would check around the idler pulley area,make sure housing isn't cracked.
This f#%* car, under further inspection I noticed the flywheel is cracked. Working on the ground is a mother f#%^*%.
You know, I was going to suggest that as well. Glad you figured it out, and yes its tough to see and its a bitch especially on working on the ground.
Yours isn't the first, and probably wont be the last. I pulled the converter/trans so I could get an impact up there on the bolts.
Sent from my HTC PH39100 using Tapatalk
