Edelbrock and SpeedPro sells the same cam grind also.
I've used the Edelbrock 204/214 cam and it was good,had a nice idle and throttle response.
Cams don't play a big part in our v6 engines,the important thing is for them not to wipe lobes and proper break-in done correctly to prevent it from happening when first installed and ran.
Be sure to add some type of additive containing zinc to your oil that you use since it has been removed from most / all oils on the market now.So the flat tappet cam will be able to survive.
