What kind of injectors can be used?
Dutchboy
I have a lot of injectors from previous Mustang builds. I dont know much about injectors but the majority of them look the same. What kind of injectors can be used on Buicks. I dont know anything about the types of impedences or anything like that. So if anyone has used any other type please let me know Im interested.
High-impedance (12 ohms or more) can be used on a stock ECM. A stock ECM can be modified with different drivers to operate low-impedance injectors.
the old blue top 36#s worked great up to the mid 11s... ran em for years :cool:
As stated; Any of the high impedance injectors will work with the stock ECM,
so, the injectors in the link "should" work fine.
Anyway, if you have those injectors, you should be ok, but, you should always go by the number on the injector.
Also, make DANG SURE they are clean.
Contact Chuck Leeper on this board for all injector info.
He is the injector WIZ! . . . . . and knows of a guy who can get them cleaned, flowed, and tested for you. :cool:
PS:
You should really first establish your HP goal and than calcuate your injector size. ;)
