what methods are you guys using to vent crankcase pressure?
ttypewhite
As the topic says. Is the breathers on the valve cover good enough with the PCV in the inatke to pull out crap in vaccum good enough? This is for people running in the low 10's high 9's that run big boost. What methods are you using?
My mechanic installed a pump and "catch can". Can has a drain valve to open occasionally. (From late model Z28 design) Seems to have eliminated much of the leaks.
