- May 29, 2001
You got spark--and you say you got gas...my question, is where are you getting gas? Do you know for sure that the injectors are squirting fuel?
Have you tried starting fluid? Shoot some starting fluid thru the MAF...If the timing is correct, it'll fire!
If STILL no fire, then I'd guess your cam sensor has been set using the wrong cylinder, resulting in a spark so far out of time that it won't fire anything!
