The first thing you need to do before cranking it is to prime it using a prime tool or disconnect the injectors & an oil psi gauge.
Hopefully if you have good gas , radiator fluid, trans fluids all topped off etc.. After its primed then I would crank it watching EVERYTHING.
Maybe someone else will chime in.
