What sensor goes where?
just plain john
El Camino a Go-Go!
Hello all. I've made a stupid mistake and need an assist. I sent my intake out for powder and am re-installing it now. When I pulled it off I removed the sensors and did not note what went where (that's the stupid part). One sensor looks like the knock sensor at the back of the block. Another has a single blade on it (water temp maybe?). The third has 2 small pins recessed inside a black plastic oval shroud. I've found a sensor guide on another side that indicates where they should go, but I don't know what the sensors do so I don'r know where to install them. Any help out there in turboland?
i believe
The one that has a connector like the knock sensor goes in the port underneath the fuel pressure reg. The one with the single flat spade goes in the front port , pass. side. The other one goes front port, driver side. Actually they all go in the intake water, just so the ends reach.
